Jonathan12uiz
Which variND are you guys recommending for the 20mm f1.7? I can't seem to find a 42mm variND. Are you guys using step down rings? and what size are you using? Does it cause vingetting?
So I should get a filter bigger than the lens thread to avoid vingetting? Because I was looking at the lcw 52mm fadernd for 78.00, but I just realized Polaroid has a 46mm for 25.00. I'm only going to use the nd on the 20mm and I need to save money so I'm thinking the Polaroid is the best option. Will it vignette? Anyone know?
If you are sure the 20mm pancake is the only lens you'll need a FaderND for, by all means get the Polaroid 46mm. I have both it and the LCW FaderND Mk.II and the Polaroid is just as good at less than half the price.
You don't need to worry about vignetting with these FaderNDs. Lots of guys seem to be overly concerned with this and it's a non-issue you can easily verify for yourself by holding the FaderND up to your lens without screwing it on, look through the VF or at the LCD, and slowly bring the FaderND away from your lens. You'll be surprised how far you can pull it away before you start to see vignetting at the edges of the frame. I see guys getting the largest FaderND they can, 72mm or larger, because of worries about vignetting. It's just not a problem. In many cases you can even use a smaller diameter FaderND than the filter thread on a given lens, if you have the right step-down ring.
Thanks for the quick reply, I just saw a bad review of the Polaroid Variable ND and was thinking of saving for the LCW, but if you have both and say that it's almost as good, I'll take the slight quality loss for the savings, I'm no pro ya know...
If I never bought anything that got a bad review by some anonymous ass hat on the web I'd never buy anything. For $25 you can't go wrong with the Polaroid, it's at least as good to my eyes as the LCW (haven't tested the $300 Singh-Ray) and it's going to make a huge improvement to anything you shoot outdoors if you like shooting wide open for shallow depth of field.
Got that link to the bad review? I need some entertainment. Please tell me he used the words "fail", "phail", or "massive phail".
I get massive flare and ghosting indoors with the LCW on the 20mm.
Just wondering here, but why would you be using an ND indoors?
View attachment 29611View attachment 29612View attachment 29613
So, the "ghosting" I'm talking about is the greenish bit to the left of the window in the first picture, the greenish bit between the door glass and the windows in the second picture, the small ghosted light to the right of the hanging light in the third picture. When shooting docs I frequently follow subjects from exterior to interior locations and stopping to unscrew a filter is often not a good option. Plus, sometimes I still need some light reduction indoors (though not with these example photos obviously) in order to maintain the aperture, shutter speed and iso I want. Maybe "massive flare" isn't a good description but I do seem to always get these ghost-ish type things in my images when using the LCW indoors. Don't have the same issue with other filters.
