Variable Frame Rate mxf files in Raylight
Mutoscope
Yes another HVX200 workflow question :-)
I've got a heap of footage i shot on a HVX at 720p at a VFR of 32fps PAL. All the footage is in mxf files on a hard drive as i did not have a copy of final cut handy to ingest and unwrap the files. I read somewhere on a forum that Raylight will convert the mxf files to .avi and also remove the duplicate frames creating a proper slow mo file that I can edit in Vegas. Can any one tell me how to do this in Raylight and what version I will need?
Final Cut is not an option as my files are .mxf files and as far as i know even the latest version of fcp doesnt support straight mxf file import as yet.
Yes it will work with Raylight and you should use the latest version 202-10. All you do is drop the MXF folder into Raymaker and the only thing I check is the self-contained AVI option. If you are using Vegas, the latest version of Raylight allows you to use the MXF right on the timeline...
D.L.
yea its drag and drop, infact you jsut drag the whole, folder over. the "contents" and "lastclip.txt" in their entirety.
