Using an XHA1 and two HV30's w/ multicam...need help
budha
At work I run a series of interviews. I finally got access to two HV30's so we can start having a 3 camera shoot. I was wondering if I could get anyone's advice on the best way to achieve this.
Should I use the clap/flash method to sync the audio?
Also, if I want to use 24p mode on all of them... I'm getting really confused on how they will work in post.
I already went to this page here: http://docs.info.apple.com/article.html?artnum=306389 and checked out the doc on workflow.
There it says I need to convert it to prores, do I have to do that, or can I just make it simply HDV again.
Lets say I import my xha1 as HDV to keep maximum quality. If I am required to make the HV30 footage pro res like the apple doc says, will that still work in the timeline? I kind of wanted to do multiclip rather than having to sync them all manually while in the timeline. Also, will I be able to have pro res and HDV in the timeline w/out having to render one or the other?
I REALLY appreciate any help I can get here.
-Mark
