mr_goodbomb
Alright, so here's what I've heard.
- You should only use one type of tape with the DVX100/A/B, namely Panasonic tapes because of the dry lube on the heads and tapes.
- To cut the time put on the heads in half, you should log and capture using another, cheaper, camera.
So, here's my question: if my cheap camera that I use for capturing isn't a Panasonic, therefore not dry lube, is it bad to reuse the tape or ever put it back in the DVX (say, if I shot 30 minutes, captured, and later wanted to use the other half of the tape), because it's been run through non-dry lube heads and might bring stuff back to the DVX heads?
