C100: Use the C100 Photo mode to test custom picture profile settings
MazingerZ
When you use the photo mode on the C100, each JPG file has a corresponding CPF and TXT file with the custom profile settings.
So when you go back to your computer, you can review each JPG image with the settings, which can be useful when you're testing/experimenting with different settings.
The TXT file is the one that you can read with any text editor.
The CPF file is the one that you can load into the camera.
Note that the C100 does not have a dedicated photo button -- you'll need to assign one of the buttons for this.
Below is an example of the TXT file:
[ CUSTOM PICTURE FILE ]
MODEL : "Canon EOS C100"
Rename : "WideDR "
Protect : Unprotect
Gamma : Wide DR
Black - Master Pedestal : +0
Black - Master Black - Red : +0
Black - Master Black - Green : +0
Black - Master Black - Blue : +0
Black Gamma - Level : +0
Black Gamma - Range : +0
Black Gamma - Point : +0
Low Key Satur. - Enable : Off
Low Key Satur. - Level : +0
Knee - Enable : On
Knee - Slope : +0
Knee - Point : 90
Knee - Saturation : +0
Sharpness - Level : +0
Sharpness - H Detail Freq. : +0
Sharpness - Coring - Level : +0
Sharpness - Coring - D-Ofst : 0
Sharpness - Coring - D-Curve : 0
Sharpness - Coring - D-Depth : +0
Sharpness - HV Detail Bal. : +0
Sharpness - Limit : +0
Sharpness - Select : 0
Sharpness - Knee Aperture - Gain : 0
Sharpness - Knee Aperture - Slope : 1
Sharpness - Level Depend - Level : 0
Sharpness - Level Depend - Slope : 0
Sharpness - Level Depend - Offset : 0
Noise Reduction : Off
Skin Detail - Effect Level : Off
Skin Detail - Hue : 0
Skin Detail - Chroma : 16
Skin Detail - Area : 16
Skin Detail - Y Level : 16
Selective NR - Effect Level : Off
Selective NR - Hue : 0
Selective NR - Chroma : 16
Selective NR - Area : 16
Selective NR - Y Level : 16
Color Matrix - Select : Wide DR
Color Matrix - Gain : +0
Color Matrix - Phase : +0
Color Matrix - R-G : +0
Color Matrix - R-B : +0
Color Matrix - G-R : +0
Color Matrix - G-B : +0
Color Matrix - B-R : +0
Color Matrix - B-G : +0
White Balance - R Gain : +0
White Balance - B Gain : +0
Color Correction - Select Area : Off
Color Correction - Area A Setting - Phase : 0
Color Correction - Area A Setting - Chroma : 16
Color Correction - Area A Setting - Area : 16
Color Correction - Area A Setting - Y Level : 16
Color Correction - Area A Revision - Level : +0
Color Correction - Area A Revision - Phase : +0
Color Correction - Area B Setting - Phase : 0
Color Correction - Area B Setting - Chroma : 16
Color Correction - Area B Setting - Area : 16
Color Correction - Area B Setting - Y Level : 16
Color Correction - Area B Revision - Level : +0
Color Correction - Area B Revision - Phase : +0
Other Functions - Setup Level - Level : +0
Other Functions - Setup Level - Press : Off
Other Functions - Clip At 100% : Off
