USB 2.0 Cable for HVX200 ??
givemefood
Hi
I own the older HVX200... Does anyone know what USB cable it uses? I believe i lost mine.
I'm trying to connect my HVX to my new PC to install the P2 software and i'm unable to do that without making the connection.
Please advise. If you can email a link to this USB that would be even better.
Thank you
I have several USB to mini USB cables that I've used with the HVX200 and 170 and all work -- all came with small USB HDDs.
If that helps.
Are you sure that's it?
I also have several USB cables but the end that connects to the USB port is common but the other end can be different depending on where it's being connected to.
So if you are absolutely sure i will go ahead and order it. Let me know.
Absolutely that is the right cable.
Of course I'm not sure you need a 10ft one...
But Nick is absolutely right - you need a USB cable with a Mini-B USB connection.
I would have sent a link to a shorter cable, but I always feel safer with a little extra so I can place the cam someplace stable in any situation.
