Urgent!!!! Problem digitizing footage
stateoftheart00
I am using the CANON HD HX A1 camera. I am unable to digitize my footage and I've tried a number of solutions that have ended up fruitless. I've done the follow and gotten these problems. And to note, the footage is fine when i look at it on the camera but on the computer it gets messed up. I am unable to view it through the hd decks. Please please assist me in my video downfall.
Attempt #1: On final cut pro when i log and capture, i put the in and out markers. i try and log the clip. they are loged but are not capture. i set it to the right place and saved my project. these are my settings:
Sequence present: hdv-1080p24
capture preset: hdv
device control present: hdv firewire 25 fps
video playback:none
Attempt #2: doing the same thing, i tried changing the user preferences. i unchecked "report dropped frames during playback:," "abort eet/pvt on dropped frames,"abort capture on dropped frames". i chose "warn after capture" on the drop down menu. When i log and capture, the same thing occurs.
Attempt #3: i then try in final cut pro, the log "now" button. When i try this, it says the following: "capture was stopped due to a problem with the incoming stream. this might be a problem with the tape. all media up to this point has been preserved."
Other attempts: same things occured in premiere.
If you can please help me out, it would be much appriciated because my video is about to get ghettofied.
Shouldn't your device control preset be set to 24 fps, not 25 fps?
I would try quitting final cut pro, plugging in the camera, and then opening FCP. Try View>Refresh A/V Devices, then try to capture.
Good luck!
-Ryan
