uprezed and using Neat Video
Thanks commalot.
So is there a suggested workflow for this if you're planning on uprezzing? Is it better to clean it up with NeatVideo before uprezzing, so you don't end up uprezzing the noise? Or is it better to clean it up after uprezzing because maybe NeatVideo can make the uprezzing look better?
Also, did you uprez with AE? Happen to do any comparisons doing it with AE versus instantHD or FCP or anything else? I have Boris Continuum which, I think, also has an uprezzing feature in it. I'm just curious if you tried more than one uprezzing option and determined that one worked better than others.
Definitely use Neat Video on the original before upscaling.This where 90% of the noise reduction occurred. I used it again on the upscaled file but it was pretty clean to start with.
I've now uploaded a test file that shows the difference. Go full screen to see the difference.
http://www.vimeo.com/4214386
I bought the AE plugin but only because my ancient version of Premier won't do HD.
