Uploads as one continuous file?
808Yoshiki
I just got this used A1, and when I upload it comes out as one continuous file even though I know it should be broken up into individual clips.
Anyone got an idea why this is happening? I tried copying the settings from my other A1, and it still does the same thing.
Thanks in advance!
Did you figure it out yet? If you recorded with continuous time code, try stopping the A1 cam upload at the end of each clip.
Cheers.
Theres a far easier way. Most programs have an option to split the clips for you no matter what time code you use. I use premiere and the xha1 with no problem splitting clips. Make sure the "Scene Detect" is checked. It will split the clips automatically as it captures the entire tape without the need to start and stop your capture manually.
