ovjamaica
scannon said:Note that converting 4:3 aspect to 16:9 aspect display is not uprezzing. Uprezzing to HD involves enhancing pixel resolution as well as the aspect conversion.
I think you misunderstood ncje's posts. Are you familiar with disjecta's method using Photozoom? It's not about just changing the aspect ratio. ncje is actually uprezzing the footage for use as 16:9 footage. For more info on the subject try here.
jade8472 said:I have an FX1 but I don't have the hardware needed to edit effectively in HD , so I usually just shoot HDV and then downcorvert it it SD.
Why not just use proxy footage for the edit? There are intermediate's for HDV for Premiere, Vegas and probably most of the other NLE's. Seems like a waste to shoot in HDV just to downconvert it. Well, I guess since your end product would be SD it doesn't really matter. I just wanted to throw the info about proxy footage out there. If you already knew about it then sorry for the repeat.
