Chamber005
Carbonite Member
So I've got my little audio set-up, and while I've always had a pretty good "ear" for music and dialog, all that means is that you can mimic well -- it doesn't mean you have any idea how to actually play the piano.
I can listen to the voice audio tracks and hear that something isn't quite right (or, natural) about them, but Im not sure exactly how to go about finding the best timber.
As most of you know I'm using shoddy equipment, but it's what I've got to work with so there we are.
My mixer is a Xenyx 502. I can pretty much play with the Trim (+10-+60), High Eq 12kHz (-15 - +15), Low Eq 20 hz (-15 - +15), and obviously volume and pan.
In addition, my CM 217 CAD mics have a swtich that takes them from 0 db to -10db.
SO all you audio fanatics -- how would you adjust these levels for the best possible voice recording? Everything is shot indoors (if that matters). I'm getting some decent headphones for the actual shoot, but until then all I have are crappy ones that don't block out enough noise -- which means I have to actually record tracks and play them back on speakers in an enviornment that is not the quietest to begin with.
I'm doing what research I can, but I'm pretty swamped in every other facet and ANY help would be hugely appreciated!!
I promise I didn't mean to skim over audio. I was supposed to have help and no longer have it so I'm scrambling to do the best I can in the few days I've got left.
Thanks!!!
Thanks!!!
