vision_filmz
Carbonite Member
More specifically the lighting techniques. Anyone that has any kind of expertise please direct me to the correct area
http://www.youtube.com/watch?v=hmP7TYtDVUU
Nothing that can't be achieved without large light sources, gels and expert color grading.
what specific part of the vid you talking about? the performance section is pretty easy. If i was Dping this:
Large Diffused source overhead (large silk with 1k/2k tungsten or large Florescent fixture like a couple 4 ft kinos. I'd add a 400diva or 650 tungsten(depending on what i want) with large diffusion flagged off to prevent light spill, just a bit off camera to the side for a bit of fill due to his hat. ( You dont HAVE to...but thats what i'd do) .Wet the ground and make sure not to blow out his face like in this vid.
1.2k hmi in the background gelled (if u want green) or you dont even have to gel that if your white balanced to tungsten which will yield a blue colour and more light output.
those 2 fixtures on the ground can be 2 1 ks gelled. Add smoke to the mix and your done.
And shoot on Neutral Dialed down and low ISO because of the amount of light you can get a nice clean image. shoot at 5.6 or for wides or even f8 ( may require more lighting) and 2.8/f4 split (yes even if you a faster lens) for close ups. You still get nice shallow DOF but with a sharper image. You should have enough light for you to shoot whatever stop you need to. Of course thats not always the case but if you have a budget that allows it then great. I dont want to be forced to shoot at an fstop.
Grade accordingly.
its actually similar to a look i may go for in an upcoming vid i may be doing. not sure as yet.
Those aren't cigarettes.....lolAnd a lot of cigarettes.
! and 2K's are not even close to what this what lit with. Think 4K or larger HMI's and large (12X12?) diffusion.
Grade accordingly.
it means shooting between those fstops...so 3 or 3.5What exactly do people mean by saying something like "2.8/f4 split"?
In this set up... HMI through the door (1.2 minimum), two par cans on floor and at the very least a 4foot 4 bank Kino very high and 45 degrees to the left of the talent.
Vision_filmz your sure a 1.2 hmi is out of the budget? that would really help. failing that what i'd say to you is use Kinos ( diva 400 or 4ft bank) overhead and to off axis to the camera and use a 2k tungsten not gelled around the back to get the full light output of the 2k (gelling cuts your output). balance for the kinos and the tungsten will look orange like you gelled it. Use 2 tungsten of the floor or wherever you are thinking in the scene.
If you aren't moving the camera much, you can achieve that look in post with After Effects by rotoscoping adjustment layers that emulate lighting, and tracking it into the shot. Combine that with some Action Essentials 2 and color grading, and you've there.
I wouldn't recommend it, though. Takes a long time, extremely tedious, and almost never as good as doing it on set. Especially if you want lights to be only in the background because then you have to roto everything in front of it. For really simple shots, it's doable though.
Am I the only one who thought the video was extremely overdone visually and not very appealing? I didn't like the grade nor the lighting color choices... it's just too much.
