Trouble Conforming 60p to 24p
7Dpimpin
I have one clip I need to conform from 60 to 24p. In said clip, a camera flash goes off twice. When i conform it, it skips these frames.. how do I make sure these stay in the clip?
Sorry if this is a noob question, this is the first time I've had to do this.
Thanks,
Ty
When you say camera flash is skipped do you mean does not show at all or shows in pieces as know that a general rule of thumb is you dont record flashing lights on 7d because of field dominance, although could be wrong.
To conform 60 to 24p if you use final cut pro studios you can do this in cinema tools, batch list then select the clips that are in 60p click okay then from the batch list box select 24p and it will automatically start conforming it into the slow mo style. Make sure you want to do this or have back up of the original footage in 60p as once conformed it changes your original footage permanently, hope that helps
