jonpais
https://youtu.be/SJZvEe8oM6k
For a long while now, we've been keenly aware that highlights in skin tones and light-colored fabrics have been difficult if not impossible to recover in post, leading us to re-examine our ETTR method. After watching a video by Gerald Undone, we tried using two zebra settings, aiming for an ETTR of only +1.66 stops - well below what we were accustomed to. However, whereas using zebras had for years been liberating, freeing us from the drudgery of having to schlep around a monitor just for the waveforms, the new routine was beginning to make shooting an unbearable drudgery, prompting us to write only a couple weeks ago
Using zebras can be a real nuisance! Let’s say that in the menus, I’ve got zebras Custom 1 set to 55% for 18% gray (for an ETTR of +1.66 stops) and Custom 2 Lower Limit set to 94% (the limit before clipping occurs with S-Log3). Each time the lighting conditions change, I’ve got to pass the X-Rite ColorChecker to the model, take a reading of the gray card, then dive into the menus and switch to Custom 1 to check for highlight clipping. However, because it’s an exercise in futility trying to see zebras with Sony’s ludicrously subpar low resolution LCD, it’s necessary to engage magnification; but wouldn’t you know, it’s no longer possible to adjust zebras while the image is magnified, necessitating doing this dance between the magnifier and zebras – by which time the light has probably changed and the model has collapsed out of despair.
Anyhow, words can't express the exhilaration we felt - after a half year of setbacks - on discovering the secret to taming those highlights and extracting the full 12-1/2 tasty stops of dynamic range out of our a7s III.
