Probably a dumb question. Matching Canon XH-A1s 30P footage with the 7D (http://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3050 "indicated “30 fps” is actually 29.97 frames per second").
Do you record the XH-A1s 30P footage (is that 29.97?) in the Canon XH-A1s in drop frame setting or non-drop? Since the XH-A1s actually gives you a choice, which should it be to match the 7D's 30P in a 30P sequence?
I'm hoping drop frame since I've already been recording with it.
