Canon Raw Development (CRD) puts each transcoded file into it's own folder, like this:
I'd prefer they all go into a single folder but there's currently no option in CRD to do that. Fortunately, if you're using a Macintosh, it's easy to have an AppleScript flatten a folder structure. Here's a link to an app I put together that'll do it. It's not code signed, so you'll need to right-mouse button click on it to open it for the first time
https://goo.gl/GJiFKq
If you'd prefer to roll your own, here's the AppleScript code that the app is made from:
tell application "Finder"
set theTopFolder to (choose folder)
set theFiles to a reference to every file of (entire contents of folder theTopFolder)
move theFiles to theTopFolder
end tell
repeat with oneFolder in (get folders of theTopFolder)
if (count items) of oneFolder is 0 or ((count items) of oneFolder is 1 and name of item 1 of oneFolder starts with ".") then delete oneFolder
end repeat
end tell
Here's the result:
Hopefully Canon will update CRD to provide an option to put transcoded files into a single folder but this script works pretty well for now.
[Edit: I got a little fancier and updated the app and the script listed above. It now flattens the file structure and puts the empty folders into the trash so you'll end up with a folder with just the transcoded files. It does check to make sure the folders are empty]
end tell
end repeat
end tell
Here's the result:
