[quote author=mastermind link=board=Events;num=1107944754;start=0#2 date=02/09/05 at 06:38:33]why?[/quote]
Because if you shoot thin and play back on a regular TV, you'll get a lot of flicker around any pattern involving thin lines. Thick, though tossing aside a little resolution, will smooth that out.
[quote author=Shaw link=board=Events;num=1107944754;start=0#5 date=02/09/05 at 18:24:15]Depends on what you want to do. I would say always shoot THIN and then blur the footage slightly if it needs it for TV playback.[/quote]
what a weird thread. It sounds like a conversation between two people when infact it is a conversation between 7. Huh.
You just want to blur it a little bit. Use a gausian blur at about .1, just enough to blur each pixel with it's vertical cousin.
Yeah, sorry about that. I knew i wanted the lowest blur possible, I just didn't check with vegas first. you can actually apply the gausian blur with a setting of 0 and it will still slightly blur the footage, but yes barry is right, the reduce interlace flicker option is probably better.
