Thanks that helps ;DIf I had only a 5D I would probably hold on to it. That swivel screen is very handy though...
but yeah, we will see how the working with 60D is vs 5D and what are the differences in IQ. I will post results here too.
I always use the top LCD with my 5D and when you tape the back LCD for specific aspect ratio you have to use the top LCD because you can't see the numbers on the back LCD.I have a 5DII & never use the top LCD & the difference in noise between ISO 160/320/640 & ISO 100/200/400/800 is marginal at best.
Can you give some reasons?
This really is same for all cameras and lesnes since you can always stop down if you have too shallow DOF. btw, I don't do interviews. Yes, there isn't really any major IQ differences on 17-5/2.8 IS and 24-105/4 IS.F4 on a full frame camera within the 35-60mm range is absolutely perfect for interviews. You get a really nice blurred background, but the DOF isn't shallow to the point where you're constantly missing focus as one would if shooting f1.4 - f2.8 full frame. Quite frankly, those apertures only work well in controlled environments with full frame cameras because the DOF is simply too shallow. Speaking of which, it's incredible sharp at f4 even though that's wide open for this lens. Check out reviews: it has very very high resolution at f4.
Yeah that's why I will get IS lens.IS helps a crap ton for guerrilla video
Yup it has longer range.It has 24-105mm range on full frame... you've got wide angle to telephoto covered in a single lens
Going over 1250 is a no no if the project has to have nice IQ. If the noise doesn't matter going to 2500 or 5000 is the same.5D mark II's noise performance allows you to use iso 1250 and even 2500 without many problems, meaning that despite having an f4 lens, you're still good in dark areas.
I protect my camera same way no matter what sealing it has.5D mark II + this lens = weather sealing which helps for guirilla work in meh locations
Yep 5D has edge on these.Build quality... 5D mark II > 60D. The rubber gripping on my 60D is already pealing off after 5 months of use <_<
60D uses SD cards. I prefer what the 5D mark II uses because I'm less likely to lose it (this really isn't a significant point)
I've used "flip screen" since it was introduced to camcorders. I've never liked to shoot video looking the viewfinder.I have a 60D... and I'm thinking about switching to this combo. The swivel screen comes in handy when doing very crazy shots, but honestly when I'm runnin' n gunnin', I almost always have a viewfinder with the screen back in its default location. Get yourself some good ND filters, buy this lens, and you're set for indoor and outdoor work.
Canon is the sharper from the two: http://www.the-digital-picture.com/...meraComp=453&SampleComp=0&FLIComp=0&APIComp=0If you do studio work and you need uber-epic-zomg-this-is-almost too-shallow DOF, one thing I would recommend is selling your Canon 50mm f1.4 and grabbing either a Sigma 50mm f1.4 or a Zeiss 50mm f1.4. Both aren't that much more expensive, and the quality difference is very significant below f4.
I don't like to use battery grip for either video or stills.I would also recommend investing in battery grip.
I've used "flip screen" since it was introduced to camcorders. I've never liked to shoot video looking the viewfinder.p
But like I said I will most likely order the 60D and 17-55/2.8 IS in the next few weeks and test them out. If the IQ difference on both video and stills aren't enough to me, I will sell the 5D. I have good eyes, but I also have realistic eyes. So I can't be sure which way to go before I've tested and seen the differences in my own eyes.
Objectively the video out of the GH2 is demonstrably better than any of the Canon DSLRs. Higher resolution, little or no moire & aliasing, less noise even at highest ISO. Whether you prefer the overall look or not is another matter. I think that the GH2 image looks too much like video even at 24p. The smaller sensor gives a greater depth of field & there is a real lack of wide lenses because of the 2X crop factor & even fewer with a wide aperture.Okay, obviously you can get great stuff out of the GH series/ m4/3 cameras, but you can't just argue for arguing sake that its images are on par with Canon APS-C. Simply not true, no matter which way you chop and screw it.
Or how about if I buy waterproof case instead? Thanks for reading the first post before replying :shocked:Keep the 5D and get a nice set of Nikon primes or if you've got the money get the Zeiss Compact Primes with a Nikon mount (more compatible with other camera systems.)
Because I made it super clear that I'm getting the IS lens for handheld shooting.
You just have to know what you are doing. If you are trying to keep the camera still while handholding then IS will do a great job. If you do whip pans & move the camera about it will make the picture worse. If you use an IS lens on a tripod you should switch off the IS before panning.Is is Good, but sometimes bad. When you have a lot of movement using a lens with IS on it actually creates a very nasty wobble with your image. Be very careful using IS, sometimes it's hit or miss.
I made the simple suggestion you change the way you're thinking about shooting handheld. IS is off in any case. That was one of the first DLSR rules I learned.
Yeah lets lock all threads you don't like.
