I was under the assumption the adapter itself had controls on it for those features and didn't use the camera controls.
If someone built a Canon EF lens adapter that made contact with the lenses and GH1 contacts, could a future version of this hack enable autofocus and image stabilization of Canon EOS lenses?
BTW, the hack would have nothing to do with that.
I don't think you guys are on the same page I'm on. I'm talking about controlling the EOS glass with the GH1 itself. Change the aperture in the GH1 with the dial and it changes the aperture on the canon lens. Press the shutter button down half way and it autofocuses, etc. I would assume you would need to hack the camera to communicate properly with the canon lens.
Well. That's no fun.
Just to add to your woes, even if you could get a panasonic camera to output canon lens commands, you have the problem of contact alignment - those are the little metal thingys you find on modern camera bodies and lenses that allow electronic communication. So you would still need a relatively complex adapter that would connect the right pin on the body to the right pin on the lens. Not a cheap proposition to start with.
It's a firmware thing. Panasonic has established a rather spotty track record of auto-focus support for legacy Four Thirds lenses with its Micro/Four Thirds cameras. There have been at least four generations of Panasonic cameras with varying degrees of auto-focus support, detailed at the following links:OK, I have a GH1 and a Zuiko 50mm f2.0... It does not auto focus but it does use the manual focus zoom assist... Anyone have any idea why and whether it is a firmware thing?
