Ok guys and gals...I will try to make this as simple as possible...and hopefully you can help me make it more simple!
Help me understand please!!!
The DVX100 shoots in 480P, which = Standered Def = Viewable on regular T.V's or anything else that is SD as well. This will also burn a SD DVD. CORRECT?
The HVX shoots in 480P/720P/1080i...which has the capablity to shoot SD & HD. But you can only view the HD on a HD monitor. Even if you shoot on HD you would have to burn a DVD to a SD to view on a regular monitor. CORRECT?
Ok now the real questions...
If you have nothing to view the HD shots on...then why shoot in HD? And if you shoot in HD...and make a SD DVD of the footage...will you still see a difference in quality vs. the SD of the DVX100, and why?
Am I correct that if you shoot in 1080i lets say, and you edit in FCP5 in a HD timeline and burn a DVD in DVDSP4 to be seen on a SD monitor, the footage would be better, sharper, cleaner, than if you shot on the DVX100 and transfered a DVD to SD, because when you shot the footage...there is still more information recorded?
I hope I am making some basic since...
Can someone please break down in a simple format the basics of shooting 480P, 720P, 1080i, and how you would then use each one to the best of it's ability in a standered def monitor.
I hope I made some sort of since guys and gals
Thanks for the help...
Jeremy
Jeremy
