The Sony FS 100. Want one, but a bit nervous
The thing about Rokinon is that there are cine and non cine versions (and in various mounts). I would hold out for the cine versions.
Also, one other thing to consider is that some people are crazy about speedbooster adaptors. I don't currently own one, so I'm not the best person to talk about this. But the point is, for any lens you use with a speedbooster, the lens should cover full frame, otherwise the lens will vignette. If this isn't clear to you, read up on it. If you have no interest in speedbooster, then this becomes irrelevant.
Jim,
Just bought a vintage Canon FD 50mm 1.4.
I totally hear you on targeting the cine version for a Rokinon...
Reading kind of mixed reviews on the need/benefit of the Atomos Ninja
wrt to impact on IQ.
They aren't cheap, but I think one might be good for smoother - edit in cam! - workflow,
plus the 5" monitor. Geez, still getting used to being a IMAC guy, after
a lifetime w/ PCs. Brain is an Olympic pool with eight swim teams in it, lol.
Not sure where I stand on speed boosters...
I would be one of those speedbooster nuts, here are my tests with it.
I would suggest: Tokina 11-16mm f/2.8, Samyang 35mm f/1.4, and Samyang 85mm f/1.4 (their two best lenses, together with the 8mm fisheye), speedbooster and regular adapter. That gets you a set of 16-24-35-50-85-135 in terms of FF-equivalent, for a total of about $1750. I would get them in Nikon mount.
Or, if you want even better image quality (not necessarily sharpness), NEX-to-LeicaR speedbooster and full set of Leitz Elmarit-R lenses, which is what I have right now. 24+35+50+90+135+SB should be around $3000 (for the 50, get the summilux f/1.4; everything else, Elmarit f/2.8)
Agree - a booster can only do good things.
As for a recorder - im not so sure, you might gain 5% IQ but also you have got a chain that can break.
S
Hi.
I just wouldn't buy an extra recorder.
What are you winning? 4:2:2 instead of 4:2:0 colour compression. Better (but also bigger) codec, not neccessarily better quality.
What are you loosing? Compactness (extra cables, batteries, storage...), AVCHD noise supression (yes, image noise is higher in ProRes over HDMi)
There might be situations, where the extra colour information comes in handy (green screen to mention one), but most of the times it just isn't a bump in image quality.
Regarding lenses: I use one 24-105/4,0 from Canon on a speedbooster. My "pretty-much-everything" lens with some downsides only (distortion on wide end).
On the fixed focal side: There's a set of nice modded Canon FD Primes (24/2 - 35/2 - 50/1.4 - 85/1.8 - 100/2.0 without speedbooster so far.
Why don't I use a speedbooster for my FD's? With a speedbooster you gain some light (approx. 2/3 of a stop), your effective focal length shortens ( x0.71), the middle of your image will even be sharper (in some cases), the edges of your picture will be even more soft and mudgy...
Frank it is good to see you here again . You work with BMCC now . What do you think it is easy to match pocket camera picture to fs100 ? Both produce so organic picture .
It can be done with careful lighting on the FS100 side.
For the record: I never been away, just writing less.
It can be done with careful lighting on the FS100 side..
Can you explain little bit more ? Please
I am thinking to get pocket like a B camera . I am afraid of low light , and how easily I can match them both .
This forum is not the same without people like you Frank
Is there any way to push Sony to give us new firmware S-log ???
Frank I like to use your PP G-LOG ULTIMATE , specially outside , but I find to much contrast look . I use zeiss lens and that may be a reason of that . Could you advise me what I spouse to change in your PP to get less contrast and keep DR .
http://frankglencairn.wordpress.com...imate-1-0-picture-profile-for-the-sony-fs100/
For starters, expose the BMC to the right and the FS100 to the left, since the FS100 is better in the shadows and the BMC deals better with highlights.
To make the ULTIMATE less contrasty, just up the BLACK LEVELS a few clicks till you like it.
Camera is here! But, I have a nasty cold. :( Feel crappy...
And worse, I have a totally noob question...
I am an iMAC user. Is connectivity for capture via USB?
Previously, on the H20, I used FireWire to Thunderbolt by way of an adapter.
I thought USB couldn't handle video? I have one of those 128G Sony cards...
and can't believe USB can handle that...
Anyone?
