Ok, bare with me on this post. I made the switch to P2 this week, they wooed me with the 16GB rebate card so I sold my FS-100 for $1500, bought a pristine Powerbook G4 (last gen 1.67 GHz, 1 GB RAM) on eBay for $700 and plan to use the extra money to buy another card later this year.
I love P2, yet figuring out a specific workflow has been a chore at times, this forum is amazingly helpful, but sorting through it all is conflicting, and a little lacking on P2CMS since it's so new.
But here's what I'm doing (depending on my accuracy this may also be helpful to people new to the workflow as well):
- Insert Card into PCMCIA slot of Powerbook.
- Make sure it's Write Protected, as this supposedly prevents the artifact issue.
- If your computer doesn't see the card, you probably haven't installed the driver yet: https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/
- Open up P2CMS and use the File -> Export tool to put MXF files on an external hard drive
- This maintains the P2 format that FCP (5.0.4 in my case) recognizes
- I don't use the "Do Compare" function as it doubles the import time.
- Verify Data is on Hard Drive (I just visually glance over?)
- Eject P2 Card in Finder, then Pop it out of the PCMCIA slot
- Switch P2 card to non-write protect, re-insert card
- In P2CMS: Select All Clips from the P2 Card, then go Edit -> Delete and confirm.
- In FCP use File -> Import -> Panasonic P2, find your hard drive folder, import the clips.
- If you have Raylight (which I'm considering) it will keep the files in their MXF format as opposed to wrapping it in a quicktime format.
- Am I right in using export instead of ingest in P2CMS? The P2 format seems better for FCP?
- Does export differ in any way from just copy/paste the files directly from the P2 card?
- When using write-protect on the card and the Export function, I have to stay close by and hit "Ok" for each clip to confirm the clip is locked. Is there any way around this?
- There seems no way around ejecting/changing WP/re-inserting P2 card when looking to delete the files? (assuming you can't do it in camera due to live recording)
- What exactly is the Export "link" option used for?
