On the subject of 4:4:4 color space... the HPX3000 has it.... anyone know what format it uses to render 4:4:4 ?
It's the exact same format, whether recorded to P2 or to tape. It's 100mb/sec. The only time it isn't, is if you're using the 720pN mode, in which case it only uses as much bandwidth as you use frames (so, 30pN = 50 megabits, 24pN = 40 megabits, etc).DVCPRO HD when recorded on tape.
I imagine when recorded to P2 card it would be much less. Probably close to 50 Mbit/s.
As said before, that's not color space, that's color sampling. The HPX3000 can't record 4:4:4, it can only output it over dual-link HD-SDI. It records 4:2:2.On the subject of 4:4:4 color space... the HPX3000 has it.... anyone know what format it uses to render 4:4:4 ?
Yeah, that's nonsense when it comes to P2. It's specifically designed to be hot-swappable. I've done it probably two million times (maybe a slight exaggeration) with never a problem."The one thing you must NEVER do with these cards is hot swap.
Always turn camera off when changing cards. I was warned by a camera
repair tech. It states you can hot swap in the manual .....don't!
He's seen loss of data, damaged cards etc."
