What's the difference between a APS-C Lens & EF-S Lens.
What are you talking about!!!! Nikon, tamron, sigma, pentax ALL MAKE and marketed as APS-C lenses.No such thing as an "APS-C Lens". Only EF-S lenses that work solely on APS-C Canon cameras.
To quote YOU "No such thing as an "APS-C Lens". COme on man!
Why was that not your first reply then?????To clarify, there is no such lens name designation from Canon as "APS-C 60mm f/2.8" lens...that is what I meant. And I'm not saying that a Full Frame lens would work on an APS-C sensor, merely that searching for "APS-C Sigma lens" on B&H will return lenses that still work on Full Frame cameras.
And on top of that, outside of EF-S lenses, I think you can still mount lenses designed for APS-C on full frame, they just vignette.
APS-C is a format of sensor size. Manufactures make lenses that cover this format size. Canon, nikon, pentax, tamron, sigma, all sorts of lense makers. There is ZERO difference of a lens marked APS-C and EF-S. If you mount a APS-C lens on a full frame sensor, it's not going to work well. However, lots of full frame lenses (Canon L series like the 16-35, 24-105, 70-200 etc) will w "Mount" and work just fine on an APS-C "CAMERA". So without having to search what a certain manufacture "calls" their APS-C lens, just google "APS-C" lens and you will get hits that include Canon, nikon, pentax, tamron, sigma, all sorts of lens makers that are "compatible" with APS-C cameras such as the T4i, T3i, the 7D, the 60D.
Semantics, there is no difference. EF-S is merely Canon's nomenclature for APS-C, just as DX is Nikon's way of saying the same thing.
Whether whoever labelled it calls it such or not, every EF-S lens is an APS-C lens. Not every APS-C lens is an EF-S lens however - only the Canon mount ones.
EF-S is actually for APS-H isn't it...
