The Best Method Of Deinterlacing GH2 footage
That link/method you posted is rather out-dated.
Me myself I use Avisynth and yadif or Tdeint, fast easy clean, excellent results and all freeware/open source.
Then for more specialized cases most pros use Fieldskit, although I do not have much experience with that.
good luck, ninetto
Different? From the affereffects trick you posted?
Well there are many different ways to deinterlace and avisynth offers you all of them depending on which filter you use. What's best depends on the material: lots of motion, what typed of motion, format, noise, etc... and how fast you want the job done...
but here the low-down on deinterlacing can be found:
http://www.100fps.com/
If you have never used avisynth, do not be afraid to try. It looks scarey at the start, but in fact it is much simpler to control and tweak than much "mainstream" software.
If you need a starting tip, just post again.
Here are a list of filters for avisynth, take a look at the deinterlacers:
http://avisynth.org/mediawiki/External_filters#Deinterlacing
