I finally got around to buying the GH5 XLR adapter, and ran it through my normal noise-floor tests with my SD MixPre-D mixer. The results were good, but not noticeably better than using the GH5 3.5mm MIC input jack.
To test for noise-floor I use the 1 kHz test-tone feature of the Sound Devices mixer to set the recording level to -12 dB, then I record 10 seconds of audio with the test-tone, and then I switch off the test-tone and continue to record for another 20 seconds. After the audio has been recorded I bring the video file into MAGIX Vegas Pro and use the RMS audio meter with a range of 0 db to -90 dB to see where the test-tone and "silence" sits on the meter while playing.
Using a passive BeachTek XLR adapter with the GH5 3.5mm MIC jack I see a noise floor of -72 dB RMS when recording LPCM audio, which is pretty good for a lower cost camera. (I've seen noise-floors as low as -88 dB from higher-end Panasonic and Sony ENG cameras)
Using the DMW-XLR1 XLR adapter I see a noise floor of -75 dB RMS when recording under a variety of formats. I tried MP4 recording both h.264 and h.265 CODECs. I tried MOV recording 48 kHz/16-bit, 48 kHz/24-bit, and 96 kHz/24-bit formats. I tried recording XLR channel 1 to both left and right audio channels, and I tried separate inputs for both channels. All of these formats showed the same -75 dB RMS noise-floor, which I think is limited to the noise-floor of the audio circuitry in the GH5 camera.
So in summary: The DMW-XLR1 adapter lowers the audio noise floor of the GH5 by about 3 dB when compared to using the 3.5mm MIC input with a passive BeachTek XLR adapter. So not a big difference when it comes to noise-floor.
That said the XLR1 adapter is an easy way to connect XLR mics to your camera, it provides 48 volt phantom power, it provides a limiter to each channel, it allows you to record one XLR mic to both left and right audio channels, it provides audio gain to each XLR input, and everything runs from the camera battery which makes for a compact audio solution.
...I did not test how clean the XLR1 audio gain was because I really want to compare the XLR1 adapter preamps against the Sound Devices MixPre-D mixer, and for this I like to record a live musician with a good voice so you can clearly hear the difference in audio quality. Hopefully I will get a chance to do this later this summer.
