Tascam DR 40 - Cheapest option to use with a mixer?
prexdealer
I checked the sticky but it hasn't been updated since 2014.
I have a PSC Promix and a Tascam DR60. But the 60 is a bit bulky and was bought originally to be used with my dslr (never happened).
I just need something to capture the audio. I am just using a shotgun mic, so I probably just have one channel. But I hate to be short sighted about this.
Also, is there a cheap recorder that can be paired with a wired lav?
Thanks. Just trying to get back in the game, been a while.
I use the Tascam DR-40 all the time with my GH4. I can plug in both wired (XLR) and wireless lav mics, as well as line or mic level audio feeds from an external source via XLR. I then run a cable from the Line Out on the Tascam to the Mic In of the GH4. Works like a charm.
The DR40 is decent. The single channel mono mode is useful with just one mic, as is the +4 line level input for using with pro preamps/mixers and has he saftey track options. The downside.. it isn't very 'bag' friendly, no rotary or linear faders, and the HP amp is somewhat anemic (20mW).
Addendum- The latest firmware has a slate tone option
I'd take the DR-60D over the DR-40, having owned and used both.
I'm working on an update to the sticky, but one thing that has not changed is that the handheld recorder is simply a clumsy design for bag use. The form factor of the DR-60D is mich more amenable to control and meter access alongsode a field mixer.
I have a DR-40 and have very annoying noise issues with sensitive mics plugged into it. Google "Dr-40 helicopter noise", there are some workarounds but they are iffy. If you have a proper mixer before it and you are feeding it a line level signal there shouldnt be any issues, but if you want to use the preamps (or god forbid phantom power), get something else. I've worked with a roland R-26 and it is leaps and bounds above the tascam, very silent preamps compared to the DR-40, nice big usable pots instead of changing gain in a menu, all that jazz.
The MixPre has a "helicopter" noise with some mics, though I think people were calling it "motor boating" In the MixPre's case it had to do with some mics drawing a lot of phantom power and that caused the power-supply to oscillate. The fix was to use 48V or keep the low cut in at 80Hz. Since I almost always am doing both it was never an issue for me but you might try the above and see if it helps.
BTW the DR60 doesn't have any "Pots", those are rotary encoders, which is why some people balk at the "step" nature of the volume control. Kind of ironic since I haven't heard that about the DR40 and it uses a button to increment in steps...
I agree that the DR60 wins on form factor if you are using it in a bag. It loses on being able to record stuff with out any other gear.
I like the DR40 a lot for grab it now recording and it is a good backup. I have a recorder that is much more bag friendly and I wouldn't want to try and use the DR40 in a bag, it would be a real PITA.
I used to occasionally get the "motor boating" artifact with my old PortaDat, engaging the high pass filter stopped it. I've also read of this happening on some SD 302s, but never experienced it personally. According to SD, the HPF fix is the same. However this fix may not work on the DR40 as the filter is after the input stage... same with the limiter.
One thing to mention about the DR40:
We have been getting a lot of interference from cell phones on these, needs a 2 foot minimum or the RF signals can (and do) get into the audio. I'm willing to bet that the case is not shielded in any way and that it also applies to most of the other devices in this family. In short, turn off your phone and ask your talent to do the same. Silent ringer is not enough.
