Forrest Schultz
Hey guys! so i finally finished my Project, and that was to make a producable Viewfinder for my T2i from scratch. Everything seen was first sculpted, then molded, then finalized, and molded again. These pictures are of the first castings of the mold, and while they aren't perfect, i was excited as i wanted to put it all together and see how it worked.
The Loupe has a +10 58mm lens for magnification (i don't know what magnification level this equates to) and the Rubber eycup has a empty 58mm ring imbedded to screw on and off of the loupe. You can see that joint looks a little rough and this is because i am still getting used to pouring with these molds. Also the rubber eyecup was not cast under pressure so you can see trapped air in it. But this basically gives the general idea.
I wanted to do something different and while i might have been better off just buying a viewfinder straight away, im proud that i was able to make something like this with my basic knowledge in sculpting, fabricating, and molding/casting.
Oh yeah. the loupe and the mount arm are both cast in a black high strength urethane plastic, and the eyecup in a soft 30 shore Urethane rubber.
Also i don't mean to be tooting my own horn if it sounds that way, i am just excited because this is the first time i have posted about this so its been months of just working in the dark.
