Okay, well after numerous failures of my previous editing station, a custom built pc, I have decided to switch to Mac... but I'm unsure of which configuration I should get... any suggestions, tips, or advice?
#1.
15" Macbook Pro
2.4 ghz Intel Core 2
Apple 23" Cinema HD Display
4 GB RAM
200gb 7200 rpm hard drive
#2.
17" Macbook Pro
2.5 ghz Intel Core 2
4 GB RAM
Hi-res screen upgrade for full HD (might use it as a field monitor)
#3.
24" Imac
2.8 Ghz Intel Core 2 Extreme
4 GB RAM
1 Tb internal harddrive
EDIT:
P.S.- I'm also going to be buying all new software to work with. I used to be a Adobe user, so my knowledge is pretty much limited to Premiere and After Effects. I'll be buying Final Cut Studio 2.0 for sure, but I'm still not sure about Shake 4.1. The good side about switching to Shake after a couple years of After Effects is that I would be familiar with both programs and "supposidly" Shake is better for vfx and compositing. The bad side being that I'm very new to shake and I'm not sure if its integration with FCP is worth the learning curve. Any suggestions? Thanks
I'm completely torn between these three options. Any advice would be greatly appreciated! By the way, I'm doing primarily HD video editing for my own short films. I also do some small proffessional work on the side. Thanks again!
#1.
15" Macbook Pro
4 GB RAM
#2.
17" Macbook Pro
4 GB RAM
#3.
24" Imac
4 GB RAM
EDIT:
