I'm writing to get some opinions on a good general purpose lens to put on my GH1.
I've read through some of the tutorials, one that stated this
I do not plan on doing much zooming at all, primarily shooting some videos for a band project, and could probably use a fixed lens that gets in a normal/decent amount of area.
Should I stick with some 50mm lenses, or go a little smaller? I'm just getting back in to photography, and could use a few tips on a lens or two to consider. Thanks in advance for any replies.
However, I am wondering if any of you here might have a few recommendations on some good lenses for me to consider, based on your experience or opinion.Lenses.
On GH1 you can mount almost every lens ever made if converter exists.
Most undervalued lenses came in Minolta MC, Olympus OM and Canon FD mounts (as they are not actual anymore).
Pentax is top in the price, generally, as you can mount very old lenses even on latest bodies, including low end.
So... I suggest to select two mounts and buy converter for each of your lenses.
Two mounts just allow you to save money and widen lens selection.
Small problem. It is very hard to find all necessary manual wide lenses for GH1 (2x crop). Most of manual lenses start at 28mm, 24 price is bigger and 20mm is even more pricey (and it is just 40mm normal lens on GH1).
So... If you want to go primes my current personal suggestion is:
- 28mm Vivitar F2.0 28x FD ($100),
- [ 14mm Samyang F2.8 Pentax ($380) moved to reserve to fact that it is very good and very sharp, but generally require video processing due some distortion present. ]
- 50mm SMC-M 1.7 Pentax ($60) or 50mm Canon F1.4 ($70),
- 85mm Samyang F1.4 Pentax ($270).
