DannayZay
Yesterday was a pretty daring production: 500 people inside a tent with THREE jib placements -- yes we had to move this rig indoors -> outdoors -> indoors. We managed to move this 12' jib like a well-oiled NASCAR crew. Anyway, I just wanted to share that it IS possible to use a C100 Mark II on a Jimmy Jib with full Iris, Servo-Zoom, and Focus control!
After a bit of research with my jib guy, we figured out that the only EF servo lens capable of wide to tight range with a servo zoom and connection is the Canon 17-120mm lens. We had to buy a $250 20-pin cable for the Servo connection, but WE GOT IT RIGHT and worked without renting the lens for a test run! Iris and focus was controlled with a separate rig on rails that connected to the jib's brain box. Powered the servo and camera with the V-mount battery, which also helped counter the lens weight.
Since our C100's close-up cameras had to be placed in the back of the tent, I was also faced with finding a >200mm EF lens that wouldn't be as heavy as the 17-120. My second solution that also worked was a 70-200mm F2.8 and 2x Extender III, supported on rails and Sachtler DV12SB's. Probably could have benefitted from being on a beefier head for 400mm...but it did the job in the REALLY TIGHT tent.
Thought I'd share some pictures below! We had 5x C100's deployed:
Can't wait to share the recap once its done
