C100: Strange color on startup...
Michal Liszcz
Hi!
Is the Canon C100 owners can confirm this weird behavior while turning on camera?
It is normal? Honestly I do not know if I had seen it out at the very beginning.
I have a camera less than a month :(
These strange colors can not be recorded.
Example of strange colors:
Please help.
Hi!
I have a camera less than a month.
Example of strange colors (I can not add the embedd YT code)
Looks normal to me -> the colour shift is when your picture profile kicks in. When you start the camera up, I presume it loads it either EOS Standard, or no picture profile, so everything is very saturated/punchy.
You have Cinema chosen, so when it kicks in, you'll see the drastic change in colours/range you're able to see (if you have zebras on, you'll likely see zebras at first, then when the cinema profile kicks in, they go away, due to having much more range).
Phew, thanks for the reassurance. Actually you're right with a zebra. At the beginning, they are - then the colors will return to normal and disappears.
In fact, it looks as if there was no profile.
Black balance does not change anything.
I did not notice this just from the very beginning.
It is possible that appeared after a time?
Thanks for yours feedback!
