ramsaur Veteran Jul 10, 2010 #1 I just got a 32GB Class 6 SD card, I popped it in and hit record and after about 5 seconds it stopped recording! Does anyone know what is wrong??
CiPO Well-known member Jul 10, 2010 #2 Is the the 7D or the T2i ? Does it do the same using a class 10 or an other card ? Is it the only card you got with the cam ?
ramsaur Veteran Jul 10, 2010 #3 sorry, T2i. I don't have a class 6. I have been using a Class 4 actually and it worked. But not on this class 6, very weird.
CiPO Well-known member Jul 10, 2010 #5 Looks more a brand/card issue then .... you should anyway use at least class 6 and not 4. Odd that 4 is the only one working though Which resolution you are recording ? Have you tried with the lowest ?
C Cassius Veteran Jul 10, 2010 #6 Did you see a buffer warning first? On the 7D it's a vertical bar that fills up with a dark indicator.
Derkoi Well-known member Jul 15, 2010 #7 sounds like the card isn't fast enough. Like Cassius asked, do you see the memory buffer on the right of the screen before it stops?
