Steadicam Merlin ??
I am of the (debated) opinion that the Merlin and the 5d are not friends
The combination does not have enough 'rotational inertia' to make a nice flying experience
You can do little walkies and runs that blow away hand held
if you try more complex moves, involving acceleration, stopping , lock offs or panning you are in for a real challenge
(note the Merlin promo vid does not show a lot of footage with those moves even on larger cameras)
The CMR blackbird is a product similar to the merlin that is a little bigger with the weights more spread out that appears to perform far better - remember that the rotational intertia of a mass is quadrupelled as you double its distance from the gimbal
Even the BB is a challenge to use in comparison to a heavier larger rig such as the Steadicam Pilot which the 5d is too light for unless it is in STEEL rails/mattbox/mic configutation - the Pilot needs some extra mass to make the arm work properly
Of course the Pilot is more costly and much more annoying to put on !
In terms of lenses I think 20-28mm range are optimal
None of these solutions offer the ability to focus which when matched with the 5d DOF creates problems
My prefered solutions right now are
Quick light and dirty - 5d and CMR BB
More time ? - Pilot and Sony EX1
I own all of these rigs BTW
S
I like the Merlin, have balanced many different lenses on it (I have listed 9 or 10 Merlin Recipes over at Cinema5D.com), including creating a way to turn the camera on it's side and shoot vertically! However, I do find that it frequently loses it's settings and needs to be rebalanced. I suspect that this is because it is very slightly slipping on it's mount. I have done all kinds of things to shore it up including various gaffers taping tricks on the underside of the camera, but to no avail. So that mounting stand goes everywhere with me!
Adding a bogen QR mount ?
This also lifts the camera and therfore requires a longer spar or more weight too adding to stability
The CMR blackbird seems to lock on a little better and has a gimbal riser for use with light cameras - moving them away from the gimbal
Using a seperate QR plate theoretically means ones settings are retained better too
S
