thefilmaddict
NOTE: On those last few shots I did add 3 quarters taped to the bottom weights. That seemed to help. If I buy the smaller battery will I get even better results?
thefilmaddict said:I've heard a lot of great things about using the Merlin with the HVX200 on this site. I purchased one a few months ago and have finally had time to try and balance it with the HVX200.
I've spent many hours trying to get the balance right but no luck. I've read the instructions and watched the DVD. I can't figure out what I am doing wrong. I can get it level, but once I start moving it around, it wants to tip big time. It is not stable.
If it's now balanced with the quarters, it'll be about the same with a lighter battery, only you won't have to use the quarters to get it to work (less hassle, and a tiny bit lighter).thefilmaddict said:NOTE: On those last few shots I did add 3 quarters taped to the bottom weights. That seemed to help. If I buy the smaller battery will I get even better results?
I thought the same thing. The HVX's weight seems to make it a bit more stable.Bill Southworth said:Actually, the fact that the cameras so heavy seems to work in its favor. It floats quite well.
Looks like the CGR-D08 is lighter than the one I bought, as it's a 950mAh, while mine's a 2200mAh. Good to know, yours may be the lightest battery I've seen for the HVX.Bill Southworth said:(2) I removed the lens hood and skylight filter and used a Panasonic CGR-D08 battery that I bought from dsmillerdirect.com.
R Gale said:"Hold it like a glass of water." That's great advice Mikko!
LOL!!! :grin: That was great. I can see from the video how essential a workshop like that would be. And to have Garrett Brown follow you saying "stand up straight!" I love it.mikkowilson said:Take look, and more imporatntly, LISTEN to this video I made after my experianec of the final test shot at a Workshop: http://mikko.n3.net/videos/GrandPrixSoundtrack_400K_pub.wmv that's working with big rigs, but the same advice applies to all of them.- Mikko ... every little bit counts.
