studiocreatif
You must unzip it directly in the SxS card.
pierre
pierre
I've tried everything and I can't update.
I bought mine with v1.10 so I never had to update before. I have to the SxS to SD card, so that could be the problem.
Any thoughts?
Anyone having problems with the simultaneous HD SDI and HDMI output. I have the new firmware installed, SDI/HDMI/i.Link IO set to HD SDI and it only does that. Same when I try HDMI. I only that one. Pulldown is enabled
A couple of things so far with V1.2 (as I'm not very proficient with S-Log.) Powering up takes a little longer but the looping scroll function is very welcome.
Not quite following you. I don't see any difference between 1.2 and 1.1. If SDI is enabled, output is SDI and the same for HDMI. If both HDMI/SDI are enabled, output is simultaneous and must be set for 59.94 with pulldown rather than PsF to display to HDMI (in my case, a Zacuto EVF).
This is from Sony --
If the camera is not finding a type A (Arri) lens electronic connection at boot up, it searches for it and takes a bit longer (I timed like 5 seconds longer). This will be addressed in firmware version 1.3.
Ned Soltz
