In an earlier post I detailed PTool settings for achieving stable MJPEG bitrates up to 30Mbps, producing high-quality videos which play back in-camera without read errors:
http://dvxuser.com/V6/showthread.php?t=215049
While those settings produced good results with decent indoor lighting, bitrates fell under 20Mbps in low light or highly detailed daylit scenes.
With the following settings I've optimized MJPEG encoding to produce a stable bitrate of 35Mbps across a broad range of illumination, from dim incandescence to shaded daylight. I've found this to be close to the highest MJPEG bitrate that can be reliably played back in-camera:
These settings work at the standard 720p/30fps MJPEG rate with the enhanced 4:2:2 color patch. I've recorded dozens of test videos on both Class 6 Transend and Class 10 SanDisk 16Gb SD cards without error.
In seriously underexposed conditions, I've recorded videos at 30Mbps with low noise and high contrast at ISO 800. Image quality also holds up well in highly detailed daylit foliage rendered without noticeable mud or smearing. While finer image quality can be achieved in brightly lit scenes via dramatically higher bitrates, I believe these settings produce near optimal quality without sacrificing in-camera playback.
I've published an easily installable settings file, combining my 40Mbps AVCHD High Reliability Patch with my 35Mbps MJPEG In-Camera Playback Patch, in the pinned Settings Sharing thread:
http://www.dvxuser.com/V6/showpost.p...80&postcount=5
- MJPEG E1 Quality = 150
- MJPEG E1 Table = 86
- MJPEG E2 Quality = 130
- MJPEG E2 Table = 56
- MJPEG E3 Quality = 115
- MJPEG E3 Table = 26
- MJPEG E4 Quality = 100
- MJPEG E4 Table = 4
