If you want to try the VR920 glasses Vuzix has a 30 day money back guarantee if you buy direct. The only problem with that is the street price is much lower.
Here's the rest of the bits you will need to use them with the MKII (thanks to ydgmdlu for compiling it)-
To get the best image signal, buy the HDFury to help you convert DVI to VGA: http://www.monoprice.com/products/p...=10114&cs_id=1011402&p_id=4559&seq=1&format=2
You'll need the following to connect the camera and VR920 to the HDFury...
3 ft mini-HDMI to HDMI cable: http://www.monoprice.com/products/p...=10242&cs_id=1024201&p_id=3644&seq=1&format=2
HDMI to DVI adapter: http://www.monoprice.com/products/p...=10419&cs_id=1041902&p_id=2029&seq=1&format=2
VGA gender changer:http://www.monoprice.com/products/p...=10416&cs_id=1041602&p_id=1191&seq=1&format=2
You end up with a really cumbersome wad of adapters but I couldn't find a more compact alternative and you can either strap it to a stabilizer or put it in a pocket.
You will also need a battery pack with a USB port. I bought the macally (link in above post) having some technical difficulties with it at the moment. There's some 4AA battery packs with 5V USB ports on ebay like this one- http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=300262614354 that should be OK. I'm going to get one as a backup (it might even work)
Hmmm. Never done an HDMI to VGA conversion. I did Component to VGA...
Squig did you get that HDFury majigger to work? It won't require external power?
Anthony, are you referring this model here?
http://www.vuzix.com/iwear/products_wrap920av.html
Isn't this enough in order to a HDMI route?
Which is which? I am lost.na that model only has composite and svideo out. The first pair I bought are composite and are only just sharp enough to be barely useable. however that one you linked to is higher res and look stealthier so I might end up with them if I can't get a VGA pair that work.
To get the best image signal, buy the HDFury to help you convert DVI to VGA: http://www.monoprice.com/products/pr...seq=1&format=2
3 ft mini-HDMI to HDMI cable: http://www.monoprice.com/products/pr...seq=1&format=2
HDMI to DVI adapter: http://www.monoprice.com/products/pr...seq=1&format=2
VGA gender changer: http://www.monoprice.com/products/pr...seq=1&format=2
Thank you.
To me, the problem with the wrap920av model is that I cannot use the new ML firmware. Only HDMI is possible.
Is it possible to get composite to HDMI with this solution you posted here...
...though?
If you're going to use a display device with a composite input, then just use the AV-out jack on the camera. There should be no difference in signal quality.Thank you.
...though?
