I finally got the 8 gig SxS rebate card in. For those who are waiting, it will be sent out of the fullfilment center in MN via UPS.
Despite all the effort of the fulfillment center to mess up the rebate process (the website still said, my rebate claim is not available), Sony really stepped up and intervened with the fulfillment center and solved all of the issues.
Does anyone know how I'd get power to a kino flo kamino ring light from the EX1? It says it needs 12V DC via 4 pin connection.. not sure if there's any adapters out there that'll do the trick..
PDZK-P1 : XDCAM Transfer Tool for Apple Final Cut Pro v2.7.0 * Requires Apple Final Cut Pro v6.0.3
http://www.sony.co.uk/biz/view/ShowC...BC+Tools+XDCAM
This version enables XDCAM EX clips which were shot with timecode mode set to CLOCK to be recognizedand imported into Final Cut Pro. In previous versions, XDCAM Transfer would display the error message:"Error There is no timecode calculator in timecode track builder".
The Log and Transfer plug in software utility for XDCAM EX allows any resolution of current XDCAM EX file to be easily imported within FCP using the standard Log and Transfer interface within FCP.
Works with Apple Tiger /Leopard Operating System (Mac OS X Ver10.4.11 or later) also requires FCP 6.03 or later
Instructions:
1) Create a new folder to copy dmg file to.
2) Copy file to your Mac.
3) Double click on the icon in the folder you have created.
4) Installer will launch. Follow the installation instructions.
5) Use the Log and transfer window to ingest EX files into FCP.
NOTE: XDCAM Transfer has the following advantages over Log and Transfer
Support both XDCAM EX & XDCAM Disc
Handles XDCAM EX and XDCAM Disc clips
mounting SxS & PD media at the same time
MXF export capability
Can write edited material back to Professional Disc in MXF files
Standalone browser/viewer
Browsing/viewing are possible without running Final Cut Pro
Other benefits
Full-screen playback
Cache functionThumbnail information available even after ejecting the media
Can create multiple sub clips by Mark In/Out
Log and Transfer has the advantage of working directly within the standard Log and Transfer interface within FCP.
Has anyone seen (or can point me out to) 720p60 footage (as well as overcranked) of skiing, snowboaring or wakeboarding shot with this cam? I've seen the pair of hands footage with the skateboarder which looked pretty good. I'd like to see anything shot from a boat or off skiis to see how it holds up.
