I do a fair bit of shots where there is a talking head in the foreground and the subject of the discussion in the background. My previous Cam was the 1" Canon XF400 so there was little separation (or control of the separation). I've been playing with the concept of racking the IRIS to go from a shallow to wide depth of field to do a "background reveal" during a shot, thanks to the auto vND (coupled with ISO) to keep the exposure as constant as possible during the rack. Anyway, here is one such attempt.
I need to look in my toolbox to see if I can find similar videohead handle!![]()
General
Complete name : M:\Video Editing\2021\2021 05- Mandy Day Trip\PRIVATE\XDROOT\Clip\174_0311.MXF
Format : MXF
Format version : 1.3
Format profile : OP-1a
Format settings : Closed / Complete
File size : 965 MiB
Duration : 15 s 600 ms
Overall bit rate : 519 Mb/s
Encoded date : 2021-02-05 01:32:15.000
Writing application : Sony Mem 2.00
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 4:2:2 Intra@L5.2
Format settings, CABAC : No
Format settings, GOP : N=1
Format settings, wrapping mode : Frame
Codec ID : 0D01030102106001-0401020201323001
Bit rate : 510 Mb/s
Maximum bit rate : 500 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.229
Stream size : 948 MiB (98%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
Matrix coefficients : BT.2020 non-constant
Audio #1
Format : PCM
Format settings : Little
Format settings, wrapping mode : Frame (AES)
Codec ID : 0D01030102060300-0402020101000000
Bit rate mode : Constant
Bit rate : 1 152 kb/s
Channel(s) : 1 channel
Sampling rate : 48.0 kHz
Frame rate : 50.000 FPS (960 SPF)
Bit depth : 24 bits
Stream size : 2.14 MiB (0%)
Locked : Yes
Audio #2
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #3
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #4
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #5
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #6
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #7
Format : PCM
Bit depth : 24 bits
Locked : Yes
Audio #8
Format : PCM
Bit depth : 24 bits
Locked : Yes
Other #1
Type : Time code
Format : MXF TC
Time code of first frame : 05:52:04:10
Time code settings : Material Package
Time code, striped : Yes
Other #2
Type : Time code
Format : MXF TC
Time code settings : Source Package
Other #3
Format : Acquisition Metadata
Muxing mode : Ancillary data / RDD 18
CaptureGammaEquation_FirstFrame : 0E06040101010704
IrisFNumber_FirstFrame : 5.611566
FocusPositionFromImagePlane_FirstFrame : 1.282 m
LensZoom35mmStillCameraEquivalent_FirstF : 29.600 mm
LensZoomActualFocalLength_FirstFrame : 28.000 mm
LensAttributes_FirstFrame : 0001807694
FocusRingPosition_FirstFrame : 70.8511%
ZoomRingPosition_FirstFrame : 0.0000%
AutoExposureMode_FirstFrame : Shutter Priority Auto
AutoFocusSensingAreaSetting_FirstFrame : Single Spot Sensing Auto
NeutralDensityFilterWheelSetting_FirstFr : 1/8
ImageSensorDimensionEffectiveWidth_First : 35.616 mm
ImageSensorDimensionEffectiveHeight_Firs : 20.092 mm
CaptureFrameRate_FirstFrame : 50.000 fps
ImageSensorReadoutMode_FirstFrame : Progressive frame
ShutterSpeed_Angle_FirstFrame : 360.0°
ShutterSpeed_Time_FirstFrame : 1/50 s
CameraMasterGainAdjustment_FirstFrame : 0.00 dB
ISOSensitivity_FirstFrame : 800
ElectricalExtenderMagnification_FirstFra : 100%
AutoWhiteBalanceMode_FirstFrame : Automatic
WhiteBalance_FirstFrame : 5199 K
CameraMasterBlackLevel_FirstFrame : 0.0%
CameraAttributes_FirstFrame : ILME-FX6V 7600174 Version1.00
ExposureIndexofPhotoMeter_FirstFrame : 800
Other #4
Type : Time code
Format : SMPTE TC
Muxing mode : SDTI
I have a question concerning the base ISOs of this camera. I’ve read that it essentially has two like the A7SIII, one being ISO 800 and the other being ISO 12,800. My question though is this: Is the base ISO the same in Cine EI mode as well as Custom mode?
