Sony NEX e-Mount to Micro 4/3 adapter
Jaybilizer
with a new Sony NEX VG10 arriving soon, I am hoping that someone can point e to a Micro 4/3 to Sony E mount adapter. I've scoured ebay to no avail.
E-Mount lenses on m4/3 cameras might vignette due to the even smaller flange focal distance used.
Why do you want to buy new and expensive "intelligent" lenses when you can use them in manual mode only? Also there is not a single E-Mount lens available which could not easily replaced by either an original m4/3, 4/3 or manual lens.
I've got a great collection of lenses with M 4/3 adapters, including a Fujinon broadcast 2/3rds mount lens. So if I can just keep all my M 4/3rds adapters and screw them into an E-mount adapter on the NEX VG10, it would save me from buying and fabricating new adapters.
Hope that makes sense.
Ah I see I got your initial post wrong. I thought you want to adapt E-Mount lenses to m4/3 not vice versa. In this case it should be possible, at least in theory. But you will have quite some adaptor overhead in there :-)
Since a larger sensor is used in VG10 (and NEXs), mFT lenses will very likely vignette, since they are designed to produce a smaller image circle.
