broughtonfilm
To answer Lenilenapi's question,
The fringing is visible "live" you can see it in the EVF, you can magnify the view and clearly see it. With some lenses in certain conditions it can be severe. Not something that I see for the first time - this type of chromatic aberration in lenses is common (specifically spherochromatism - a type of CA where edges of high contrast objects exhibit magenta and green fringing depending whether they are in front or behind the focus plane) and happens on any system but FS7 seems to somehow make it more pronounced (read my first comment in this thread, I have a speculation about why it is happening). Yes, if there is no chromatic aberration to begin with then there is no issue. It is important to understand it as a complex phenomenon (complex not in a sense that it is impossible to overcome or a deal breaking but simply complex, something that should be discussed in a context of a system - not just lenses or just the camera). It's been reported that the camera does not respond to the CA when shooting RAW the same way, it does not make it more visible.
I did not post in this thread to complain about the camera and (as some suggest) dismiss optical causes of the phenomenon - I too think this can possibly and likely be solved on the optics side of things BUT in order to solve it this way the understanding of what is going on on the camera side is important. In example, if it turns out that this is caused by insufficient effect of OLPF on red channel, then maybe one possible solution would be to use a slight diffusing filter on the lenses to lose a bit of lens' resolution. As observed by myself and Sam Morgan Moore it is actually the high resolving lenses that cause the problem the most - which leads me to believe that the problem is associated with aliasing (and possibly later with debayering and compression). One thing that contradicts it is that there seems to be no difference between 4K / UHD and HD modes (if the problem was associated with aliasing, I would expect to see more of it in HD where OLPF is not as effective as in full resolution) but it is probably more complex than we all think. Since the OP was asking about the fix of the issue, I think it is fine that we investigate it with attention to detail. I'd also like to hear more about Sam's post solution in Resolve.
