Peter C.
could you link the vid and its exact time? i want to see/hear what he's saying
The old “Double the shutter speed to frame rate” stems from the film frame rate of 24 fps, where when film was projected at 24 fps it looked very jittery. That's because the persistence of human vision is around 1/20th of a second. As anyone who has shot and edited film would generally know. So you shot at 24 and projected at 48. Well, that was the conventional wisdom. Projecting each frame twice with a 180 degree shutter took you well outside the persistence of vision. This is why 25 and 30 fps TV was converted to interlaced transmission to give us 50i and 60i to smooth out motion to bring it closer to how the human eye observes motion. That is why for film, we projected at twice the frame rate. To smooth out movement.I mean buying new gear instead of using what you have. Sitting at home not being used.
When shooting at 60p the correct frame rate is double (120fps). Gerald if I'm understand is saying if you shoot under that frame rate the camera isn't really filming those extra frames. So does 60p @ 60fps half the frames are the same or skipped yielding the same as 30p @ 60fps?
Peter, to clean this up as I understand your question:When shooting at 60p the correct frame rate is double (120fps). Gerald if I'm understand is saying if you shoot under that frame rate the camera isn't really filming those extra frames. So does 60p @ 60fps half the frames are the same or skipped yielding the same as 30p @ 60fps?
