The 24-105 ramps and more importantly is prone to chromatic aberration which was unacceptable to me. Hence I bought the 18-110 but use the 24-70 when needed in low light.
Hi,
which lens to prefer? on FS5 for documentary work. (with lots of interviews but also pretty much handheld situations)
the cost is not so relevant because the production company is buying...
thanks...
I'm gonna say "neither". The Canon 24-105mm is problematic...the 18-110 is slow and uninspiring.
I own the Sony 18-105mm, the Sony 18-110mm, the Sony 28-135mm, a Sony 10-18mm, a RED 50-150mm. But I rarely use any of those zooms. The zooms I use the most when shooting doc-style are my Sigma 18-35mm and my Canon 24-70mm f/2.8 II. I mix them often despite the fact that they do not color-match without some help in post. If matching is important to you, swap out the Canon 24-70mm for the Sigma Art 24-70mm.
The Sigma 18-35mm is magic.
Ideally, you'd go with the two Fuji MK zooms. But it doesn't sound as if you have the budget for that right now.
I have both, since I own the 18-110 I don't use the 24-105/sb anymore.
Do you use the sigma 18-35 with the normal metabones adapter or speedbooster?
