Something that suprised me 7d v. 5d
HDMI is live and constantly 1080i according to my television.
Also - my powered hdmi splitter from monoprice does not work with my 5d but does work with my 7d. Meaning. Buy a powered splitter and the operator and director can have an hd signal.
Lastly - the autofocus markers leave when you press record meaning that you could easily pull a 720p raw signal off the hdmi through an MXO 2 or similar box. Will post explicit tests tomorrow.
If this works it's a massive unique selling point. Does it always output 1080i or does it change when switching to recording at 720?
Holy shi*! That is so cool! So it is a better-than-DVCpro-HD 720p or direct to h.264 1080p camera!?!?
I can RENT a nanoFlash! And what a MOBILE setup that would still be!!! :)
Now RAW would be INSANE! But this isn't RAW though. If we could record actual RAW, then we would need to figure out the sensor's native ISO and expose for that to get the thickest 7D negative. Cause RAW means that you record the chip's full dynamic range with a given bit depth on your recording media, right? Then we would set exposure in post to our own personal taste, and push it as far as we thought was still nice before it broke apart or before the image looked dull from losing too much dynamic range, correct?
I mean, isn't HDMI compressed already? I am obviously not complaining here!! :D
What is the limit of the "HDMI pipe"? And can it only be filled with info gushing through it, or HDMI still work with the faucet only partially open? Is that something we can only figure out by testing how much bit-rate is worth setting the nanoFlash to?
And since it can't be actual RAW, then the ISO and all other settings would be burned into the HDMI signal already, right?
Of course, either way this is a heck of a lot of camera for $1,700!
Bbetter than HVX 720p on a S35 sensor and crazy low light is V-E-R-Y nice!!!
Am I understanding the implications of this correctly?
Not sure what you mean by 'RAW'. There's no way to send RAW from 7d sensor via HDMI because HDMI is rgb/yuv and 7d resolution by far exceeds 1920x1080. Even if it was possible you would need special software to process it (debayering and rgb/yuv conversion). So it's definitely not raw.
The fact that there's no aliasing is very interesting, though. It's been said many times that Canon uses simple pixel binning because dual Digic4 chips are not fast enough to apply more sophisticated downsampling method. This is where all aliasing is introduced - at downsampling and not at the compression stage. The sensor-resolution signal, before being output via HDMI, has to downsampled, too.
Now, if 7d's HDMI output exhibit no aliasing, then apparently chips are capable of higher-quality downsampling filtering. This, in turn, would mean that Canon limits the 7d video recording quality on purpose, by running suboptimal downsampling filter... Am I missing something?
Oh, hey.. I completely re-wrote my post. Please take a look and tell me if I am getting this right.
What you are saying about setting the limit on purpose sounds very interesting. But could it be to lower the file size and become more slow-media friendly?
Well, Red does the resolution. Not 18MP (yet) but somewhere around 12MP with Red One. ;)
I am not sure what HDMI being rbg/yuv means though.
I was referring to HDMI - you don't send red raw over hdmi...
HDMI allows the video signal to be encoded in either sRGB (4:4:4) or one of three different YCbCr (people often call it YUV, even though is analog) color spaces (at 4:4:4 or 4:2:2 chroma subsampling).
No - it's uncompressed
The beauty of RED is not RAW. The beauty of RED is REDRAW, using the REDCODE form of lossy compression. The data you get out of the camera is compressed - rather heavily compressed, actually. However, it is compressed very very (like, ridiculously) intelligently. This is the reason RED outputs in MB/s instead of GB/s but produces an image that is on par in terms of quality and latitude with "true" RAW recording, even though the bitrate is much lower.
This is, in many opinions, the real source of their revolution. Rather than recording absolutely huge filesizes with massive bandwidth, one can record something of equal quality with far fewer resources.
Dang. Spoke too soon. Aliasing is there. My trash can was as much of a definitive test as I thought.
Still great that we can capture this way, but sadly I spoke too soon. Sorry.
Thanks for taking the time to test it! Is the aliasing still there to the same extent, or lessened?
I'm not sure. The fact that the signal is always 1080i may be part of the problem. Properly deinterlacing would help. I'm not that experienced with the best ways to deinterlace.
Also - 720p60 appears to also output 1080i.
So...let me get this straight. Do you mean we are able to capture 1080i video "before" compression over HDMI? Just like my (former) HV20?
Well, for one, if that is possible then I would put up a side by side video of what came out the card compared to HDMI. I understand they will be compressed in the end but I would like to see the difference between the two even when compressed for Vimeo.
Don't think it's post-compression. HDMI is uncompressed. To support it, 7d would have to first encode and then decode h264 before outputting. Bet it's before compression
I'm sure you are correct trez. I was going to ask why hasn't anyone else found this out (and even denied it...I believe). But it makes sense that it does work since the HDMI out is live.
Hey guys,
You know what else this will be very useful for? If this works out the way it seems to be working out, using a nanoflash over HDMI with the 7D would mean no 12 minute recording limit. Would it not?
