Some recent work with hack + Zeiss ZF
prey99
Music video for "Bola de Cristal" by Costarican artist Ale Fernández (www.alefdz.com). Shot in San José and en route to the Irazú volcanoe over the course of 2 days.
CoProduced by DocePuntoCero and Argos Cine/TV (www.argos.co.cr), shot by Pedro Rey, post by Fractal (www.ffractall.com).
Lumix GH13, C settings (thanks Vitaliy and everyone else at DVXusr!).
Zeiss ZF 28mm, 35mm, 50mm, 85mm, nikon20mm, stock 14-140mm.
All Cineform Neo4K workflow, color by Firstlight.
Hope you guys like it!
Pedro Rey
Director/DP
Thank, glad you liked it
Hey guys, thanks, glad you liked it!
Editing done on Premiere Pro 2, and the "cloning" was done with good ol´ fashion soft masks (wipes actually)... no keyeing!
Pedro
Pedro
I figured the cloning was done in AE with masks... What I can't figure out is how you did it with the camera moving... Don't you have to match the motion of the shots... Did you just motion track one of the shots? Just seems more complicated when the shot was hand held. Needless to say I'm impressed.
Movement done in post
Thanks, well there are several shots, specially the "fx" ones, where the movement is done in post. During the shoot the camera was locked down...easier to composite that way! Actually, I "forgot" to add movement keyframes to the third "clone" shot (I think)...so it ended in the final version as a static shot...sloppy me!
Pedro
No lights on exteriors, just bounces
Thanks mrmoe!
Well, mostly soft bounces, foliage as "silk", nd plus pola on camera.
Used a small arri tungsten kit on the bookstore scene, a 650 and 350 watt, one bounced to ceiling for general fill, the other used for key light through some "cookie" elements to break it up a bit.
Pedro
Yes...looks great!
So...where is the "jello"? Cutting room floor?
With all the handheld walking shots etc, wondering if you had to discard footage due to artifacts.
Pedro
Great video. Inventive, interesting and generally a good vibe.
Please excuse my ignorance, but could you briefly explain what a soft mask (wipe) is.
Almost no artifacts!
@Gweilo66
Thanks man. Well, surprisingly, I did not discard one single take due to artifacts nor jello, but tt is there, if you watch carefully, for example on the close up shot in the bookstore. We did try to use a steadycam to reduce "handheldness" but the rig was a bit heavy due to an oversized mattebox and filters, and our "glider" really was for lighter cameras...but in spite of all that, jello is greatly reduced thanks to Viytaliy´s and the hack tester crew here at DVX. Some artifacts are present, specially when you do a bit of heavy handed color correction, but certainly on can live with it!
@Stoneinapond, soft masks are really just masks with "feathers", or soft edges, but since Premiere Pro does not do masks as such, I usually end up using several wipes, which do have a feather control, but not as transitions, only as "effects"... poor man´s AE if you will.
Pedro
