vcassel
First off, I'm loving what I'm seeing after :35 in this clip. It says he's using a Nikkor 50mm lens. The only Nikkor lenses I've read about are the AI ones. Is the lens this guy using in some series, or is it just a general use Nikkor 50mm lens?
Reading around on anamorphic lenses has been a bit confusing. I've gathered that the Lomo square fronts need to be mounted to Nikon (or was it Nikkor?) lenses. Is that true? Can you bypass this by using a PL mount like the one from Hot Rod Cameras?
Still a bit confused about the micro 4/3s thing. A few people here have said with great clarity that a 50mm lens adapted to the GH1 is still a 50mm lens with the same perspective and focal depth, just with a 2x crop. I believe this. If I want a 50mm I'll use a 50mm. I have a very convincing friend who's insisting that if I want a 50mm lens adapted on a GH1, I'll have to use a 24mm lens. I hate to keep bringing this question up, but I'm about to start spending a lot of money on lenses and I want to make sure I get this right.
Thanks again guys!
Thanks again guys!
