That's my understanding plus you can use the higher end SD cards as well but you are limited to 50Mb/sec. If you buy the adapter and and a 64 mini P2 card you save about $100. But then you could feed more mini cards into the same adapter.So I am guessing the new microP2 Adapter card will work like normal in my 250 using the P2 micro card? Is this correct as it will be much cheaper than a standard P2 card (once you have the adapter card)
Yes, the adapter allows the use of top-end SD cards but only at a maximum of 50mbps. For an HPX250, that would mean 1080i or 1080p at AVC-Intra50, or 720/30pN at AVCI-100, or DVCPRO50.
When using a genuine MicroP2 card with the adapter, you should be able to use any of the HPX250's recording modes.
And too bad you can't span P2 and micro P2. It seems too good to be true. There's a show-stopper with micro P2 after all. There's no escaping in paying the premium, full price for the media.
