refocusedmedia
First off, here's the PC I'm working with:
AMD 1090T BE 6-core 3.2 GHz
16GB DDR3-1600 RAM
nVidia 470 1280MB gpu
Boot\app HDD = OCZ Vertex2 90GB SSD
Storage\media HDD = 3x 1.5TB RAID array running RAID5 with 3.0TB useable
I am new to AE, and am excited to get into it. I have been watching tuts on Videocopilot and others for awhile now, and finally decided to make my first composition. I created an 11-second intro comprised of about 10 layers... 3 PSDs with trakmatted texture, a particle layer, a Ramp BG, 2 text layers with bevel\glow effects, a 3D camera and null object combo, and an adjustment layer with motion blur (12 samples, 120 blur amount) that affects the 3 PSDs, particle, BG, and 2 text layers. This comp is 16 bpc.
I have disk cache enabled, and I have Adobe set to use 12GB (leaving 4GB for other apps); background CPUs = 2 and RAM per CPU = 2GB (total cores used = 4). I tried some other settings, but these seemed to work the best? I'm not sure and am open to adjusting this further. Also, I enabled the "Secret" menu and turned on the Video layer frame purging to every 2 frames.
So anyway... I cannot get this thing to render in under 55 minutes. No matter what settings I try, it always takes anywhere from 55 minutes to over 2 hours. So far the best I found was doing Best quality, Quicktime, Animation codec @ 100% (I'm sure I could get it faster with a lower quality setting, but I'm not willing to do that).
Is this normal? Is this bad\good? I'm very frustrated, but I'm wondering if that's simply because I had unrealistic expectations going into rendering my first AE comp. I expected it to take no more than 20-30 minutes, to be frank. Especially for a relatively simple, and short, comp. Anyway... I would really appreciate some advice, help, reassurance, or even criticism. Thanks for your time.
16GB DDR3-1600 RAM
