hey,
i found a thread where Barry said
For the PAL/EU/AUS/NZ cam, set the recording mode to 720/25pN, then set your frame rate to whichever your chosen fps is. Then adjust the speed of the song according to this table:
12 fps: make song last 2.000x as long as normal; play it at 50.00% speed
18 fps: make song last 1.400x as long as normal; play it at 71.44% speed
20 fps: make song last 1.266x as long as normal; play it at 78.96% speed
23 fps: make song last 1.080x as long as normal; play it at 92.60% speed
27 fps: make song last 0.920x as long as normal; play it at 108.68% speed
30 fps: make song last 0.840x as long as normal; play it at 119.04% speed
32 fps: make song last 0.778x as long as normal; play it at 128.56% speed
37 fps: make song last 0.680x as long as normal; play it at 147.04% speed
48 fps: make song last 0.520x as long as normal; play it at 192.32% speed
50 fps: make song last 0.500x as long as normal; play it at 200.00% speed
1.So what about in the dvx?if i shoot at 50i then use a shutter speed of say 1/120 will i still use this
or will it be different because on the HVX the setting is 720/25pN???
Sorry if this is an obvious question...just need to understand.
2.What happens if you want to shoot slow motion then fast motion like what they do in a movie like matrix?where when a someone throws a punch,its silky slow then it suddenly goes really fast..will you shoot the same scene in two different frame rates?and how will that blend in post?especially in sony vegas?
HELP
HELP
